Lucky bastard, so how did you get into that did you study programming? develop software or??
I has year 12 only...
started uni, Chem eng, hated uni with a passion due to having no Fkn idea what I wanted at the end.
I just did what ppl said, oh you has good results u should do blah.
I grew up on a farm no idea what the options out there was.
so thrown out of uni as I was bored, I got a job for a telco help desk in fact a couple desks up from paul33
did well, went to work for a dot com start up..showed some skills blah blah blah travel lots
so I would like to say self made..
LOL man my 1800kg boat ain't designed for corners :P
STRAYA !
f**k I hope not as I will be going head to head with you!
aight, should give me some what of an indication just imagine 1cm off on each.. when can i try? :P wish they were 19s!
Alvin's! Aren't u after some grip? Surely you'll have more with 18s it'll definitely be cheaper aswell
ah okay cool cool, I studied I.T for 2 years after year 12 been in the workforce for about 2.5 just wondering about career paths down the track.. hard to think of many things other than infastructure management / i.t manager stuff :\
ATM just server / desktop / app support type roles..
Don't worry won't be taking my whale on the track you'll be up against me on the 1/4 mile tho
I took your advice, have had red meat for the past 4 days. I feel f**king fantabulous. Maybe take your own advice..
Watch now Ive jinxed it
Been hitting up the Vitamin C + water + good sleep too?
My advice probably works well for other people, but because I have next to no body fat and keep sharing beds with people who STEAL THE BLANKETS, causing me to wake up shivering...my advice will only take me so far :(
re work...right place right time, right skill set. I was a lucky prick end of story.
been one company for 12 years next week. started bottom level support
talked my way up since then.
i've worked hard but been rewarded such as well so no complaints
re track.
I would be keen to see it go round...(more would love someone give me some keys to take one round.)
i recon I could give run for your money on a track...straight line...i'm doomed against not just you...so many cars.
Yeh water and sleep is good! Happening a lot more since I been eating well. Also got on this stuff called orange triad by controlled labs.. Immune joint digestive system multi vit. Took it for the first time this morning just one to see if I'm gonna react. So far so good..
I'd probably get half a lap in with the current brake setup :P not taking it on the track just yet need a few more things setup before I give it a go. Would be fun sliding it around though!
Just airport / show and shine this year for me
Wrapped roof looks poo, me no likey. I am happy with how the car is now, could use a front lip of some sort.
Off to Japan next weekend. Shopping list includes, cusco lower control arms, nicer foglight globes, Carbing strut brace and anything else I impulse buy
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
