Seen it. Can't say I liked it as much as other guys.
The new Judge Dredd movie seems to be a similar style to this judging by the trailer
the story line itself is pretty poor but the fighting scenes are wicked...yeah Judge Dredd must be the u.s remake
I like this idea. Females will still steal the whole thing and store it on the other side of the bed though, as if it was a diminishing natural resource.
Obviously people who never grew up with tucked in beds that you can't roll yourself in.
I always end up stealing all the blanket from myself and it ends up on the floor.
wheeler dealers...
obtain wrx.... nice
install HD clutch... nice
install catback exhaust... not full exhaust however still better than stock i spose
install panel filter... nice
install STI brembo's and rims... nice
tune car on dyno.... nice
put on "racing stripes"... ffffffffffuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
