Lots of engineering/electrical types here huh? Good, will be looking for new recruits/graduates this year.
I have worked here as automation/electrical design engineer for last 10 years. Expanding at a healthy rate 55 employees. I have a department to grow.
www.andeng.com.au
Possibly looking for any VAC work students, too? :P
I'm glad there's so many engineer(s/ing students) ... can help me with my homework :yes:
/eng talk
OT of careers, future career seems so far away to me right now (just feel like I'm going to be in Uni forever xD), even though in reality it (hopefully) isn't.
you're already working as an engineer...
and seem fairly comfortable..
I wouldn't say a r32 as a daily as comfortable living :P
2.5 years full time work, 40years to go O_o
You go to super cheap again today? Think I saw you on stud rd?
Was driving down to dandenong via stud Rd. Would have been at 1?
Where were you?
you're better off than most. lol
and your 32 is in awesome condition brah. different from the run of the mill 4000$ r32s
bar the peeling roof
Edited by xALmoN
Also as if engineering can't lead to lots of money.
As mentioned, engineering students are taught to question and think analytically. It's why graduate programs at banks look for engineers.
Lot of ceo's, directors and managers are engineers for the reasons above.
The secret to this is that you are a business person first, engineer second. That is how you move up the ladder and not be held as a specialist in your technical field.
However, nothing wrong being a specialist either, as there is also large amounts of money to be had there too. (but you will always think in the back of your mind, ''if I was running this shit it would be less of a headache'')
/my 2cents on engineering
Haha it all comes down to income vs lifestyle ratio and how you manage it.
And owning an aging skyline is a poor lifestyle choice. Haha
About to turn right onto Kelletts
Haha did you see me on the slip lane at the lights or after?
Bin that spoiler for extra street cred
I like it :) fark having holes in the boot as well
re: xr6t aaron, I think the FGs are a bit better built goes without saying that little bit newer as well should always feel bit tight and good.
Why I say auto? because it's not a 2 door coupe remember, the auto is around .5s faster on the 1/4 mile and a stock XR6T (FG) does a 13.1 or 13 flat ish and lets be honest thats what this car has going for it straight line not track. Why buy a manual if its a cruise car / not drift or track car? Once you get used to the ZF you'll love it.
That being said buying 2nd hand I wouldn't let auto/manual really phase you just focus on a nice clean example with some good options. (Must have leather, you'll know what I mean when you compare the 2..)
But it's all just advice.. you can do whatever the f**k you wanna' do!
Loving this new insert!
fark after last track day
need
oil
filter
windscreen
rear rotors
rear pads
tyres reveresed
oh and a diff as well.
damn becauseracecar
Because racecar obsession.
You could (people do) spend endless amounts of money. Where does it stop, that decision is a hard one.
Be intradasting too see blags 86 perform at Haunted Hills in a few weeks
I'm pretty damn excited for it.
To everyone saying go lower, it was about 1.5cm lower and it was scrapping on every single speed hump, very impractical. The driveway at work is massive too, so that doesnt help. Maybe 1cm lower night be the go.
It looks soooo good in person
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
