been told its the most beautiful city in the world by more than one person..
i haven't been but definitely want to!
I can safely say it's way better than Paris, as for other cities, yeah it's strangely beautiful that I can't quite work it out. You'll need to head over there to see for yourself.
When my parents went there, they said the same I thought otherwise until I went there.
Cool we have decided to go as part ofour wurotrip next year.
Must see sights??
Astronomical clock - if you head there on Saturday or Sunday you might gate crash a Wedding as it's on a church.
Charles Bridge.
Old Prague and New Prague - basically 2 era of Prague divided by river, one modern and one old fashioned, you get the idea.
Prague Castle.
'Hunger' wall - short walk from Prague Castle.
Jewish cemetery - not quite why it's a must see attractions but I was told it's quite important bit of history in Prague by receptionist in my hotel.
Freedom steps, same area as 'Hunger' wall.
That's it off my head, pretty sure these all I've been to, and I'm sure there's more. There's a weird clock on the hillside alongside Prague Castle that I struggle to remember the name of it.
/martinstraveladvice.jpg
ill look after you, just don't buy crappy brand items, please for the love of god.
haah nah the grills alone are going to be costing upwards of 8k each i believe :)
It's not being done on the cheap
outside my house in a quiet area in newport.
that said area becoming less quiet, been ehre for 7 years and laty going down hill, neighbors had their car stolen earlier this year for some prick to get home, (was torched in altona north)
will move to bigger place next year further out so I can work on my cars myself.
My plan to purchase new bike gear today has not gone to plan, damn having to find a helmet that works whether I'm wearing contacts or glasses.
Now can't go look at a bike either, fek
Hmm, last time I bought a helmet I found I didn't have a shoei shaped head.
Even tried one of those flip front ones... couldn't get it on with my glasses on, could put my glasses on after it was on...
um yeah, I always take glasses off to put helmet on
glasses cost way too much to risk.
plus that how helmets are designed.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
