If ya haven't been banned before Leigh then post for sure it's like a rite of passage
Elevate's ya rep big time!
I've been banned twice, not quite at the 60% badass level you are :P
*waiting for people to complain they're at work and to not post that shit even after they asked* oh wait its 5:08 so it's okay
there is.
its called, 新洲米粉 LOL
or direct translation? singapore style rice vermicelli.
So basically its thin rice vermicelli, stir fried with cabbage, barbequed pork, onions, random stuff, and curry powder. nothing spesh.
meh i said apparently,,,, Also she was a headf**k
Sitting in Sydney Qantas club chugging free beers - would have come to Garage meet but alas not home early enough.... no earlier flights.
next thurs for me.
strange the qc lounge better than the buinesss one.
next thurs for me.
Have not been in the Sydney business lounge. Sucks that Qantas has not offerred me double status points yet as would easily be platinum now at half year.... (a work mate is lording his over my meagre gold). However will make Platinum maybe this year if not early next. What does the marble bathroom look like? haha
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
