you still looking at gtr's or something else now man?
Yes and no, bank now need my payslip and Coles doesn't do paper payslips anymore so I have to get via online, I can't access cos I don't have some sort of number so waiting on payroll officer to give me the number.
Once that's sorted, back to bank and wait once again...
Trying hard to look into something else but heart say GTR, mind tells me to sample other things even though it could be horrid.
Alternatively, buy cheap trasher and probably 're-shape' it as I go.
So wait and see how I go...
ahh i see man, damn banks!
yeah i can see how a gtr is hard to pass on..
so many options though, just hard to decide..
Group assessment and behavioural interview today, fun times.
/nervous
Had to print out my academic transcript; used my JDM stapler (bought from the source, it's collapsable for slimeline storage... I think it uses magnets. Magnets are friggin cool) for the first time :D.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
