a drop top ferrari 360 was parked right on the edge of my driveway a minute ago...
then some muscle-mary douchebag came out of the house opposite (tight chesty bonds and a gold chain etc etc) and is showing his mate...
clearly daddy's car as he didn't know how to open the bonnet and also thought the engine would be in there.
you should have heard how badly he was riding the clutch when he was trying to reverse it... provided soooo many lulz.... infact ima put this post in the lulz thread...
Eh? Won't the lips stick out just as far? Unless you're running spacers that you'll be removing?
What he said.
WIll sell the 2 x 6.5in 34 hole barrels (brand new but powdercoated dark charcoal) - for $400.
Washed car - shopping and then did the Eltham - DIamond Creek - Kangaroo Ground loop - awewsome day for driving. Going again!
will raise the offset as the center section will sit in a little more as the barrel is smaller
nah ill pass for that kind of $$$, can buy 2 brand new lips for that
Will just make these fit
Couple of young fellas in a Gallardo superleggera on lygon last night gorgeous car, but them looking towards an old bloke at a table when someone asked them to give it a rev and him nodding lol, wish my dad had a lambo..
The centre is bolted to the hub.. I don't think it's going to go in any further?
Actually sounds more logical than my alcohol filled imagination that I'll be going smaller than what they are now :P
http://jalopnik.com/5944568/is-a-15+year-old-texan-girl-driving-this-ultra-rare-lamborghini-to-high-school
Nah was f**kup on our side, the way the standard lips are to the wider lips we calculated wrong
So new lips will stick out 12mm more than I originally was thinking
You would think that, but not if you saw how they fit currently :P
haha oh it will be ;)
needs way more camber first though :P
lol damn i see what you mean now!
camber / flare / stretch!
lol worth a shot, will look crazy if you can pull it off :D
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
