Look like quite a bit of entertainment here last night.
Will need to organise some time of UFC Cage Fight for the Show N Shine
Pat v Ashrey
Moh V Dezz
Birds v Aaron
ill take on Leigh because were both bulkers
Everyone too scared of me huh?
as a rough guide, use the online caculator that most insurance comapnies have.
put in your details prior get quote
put in same details but tick one claim, see cost.
won;t be %100 accurate but close enough
Cheers for the idea Marty but Justcar insurance can't do online quotes for Stags... :yucky:
btw, such nice weather today!
I'm stuck in a climate controlled factory with no windows. It could be the apocalypse outside and would not see/ or feel it. And any chance for stepping out during a break isn't possible as I'm wearing factory uniform :(
What do you do for a job, again?
Bond, James Bond
Must feel good on 40c days brah
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
