Not big on the grey mid fairing, need to decide whether I'll spray it black or red...Also want to black out a lot of the silver (heatshield, sub frame etc) but no rush there....First mods will be exhaust, fender elim, integrated tail light and smaller indicators, as well as a black screen from Charles...Also got some rim tape on the way, but that'll be it for now
Nice. My bike plans have been set back, hopefully before the end of the year.
Is there any personal insurance on track days?
If you are injured, there is no TAC, so who covers you? CAMS? Any info on the internets?
http://www.oamps.com.au/Portals/CAMS/CAMS%20Personal%20Accident%20Insurance%20guide.pdf
there is cams insurance but I know it doesn't cover things like an ambulance ride to hospital etc, so I think it your health insurance.
dezz thoughts on vettel joining the ferarri team in 2014? should be interesting to see how alonso responds
I'd be torn...by my deep, deep hate for Vettel, and the fact that he is undoubtedly quick.
He'd push Alonso to be better, something Massa hasn't been in a position to do all season up until the last race or 2, and more than likely beat him on his day
It'd be good for Ferrari in terms of constructors, I'd just hate myself for wanting Vettel to place well/win because he's driving for Ferrari.
Kimi/Alonso would be my dream lineup at Ferrari, but I don't see that hapening
Yeh I guess although id say Ferrari use to be the team to be aiming for, now I think rbr / mclaren personally
Rbr seems to be well ahead on r&d and the pack chasing / whinging after them after every change
Maybe they spend more dunno..
Edited by alr33x
http://www.bbc.co.uk/sport/0/formula1/19941541
Which site?
Pm me ur number ill give you the guys mobile number
Just the normal aussie site, if its John I spoke to him on facebook just now he said they're a bit behind and it'll be like 2 weeks the plus side is I changed my front order to custom offsets from 19x9.5 +30 to 19x8.5 +17 (this will clear brembos now if I want)
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
