have had experience firsthand with the effect of appearing professional. pettet both times, hoodie/trackies/unshaven vs straight outta compton hospital with shirt/tie/hospital nametag etc. difference in his approach was like night and day
Normally $2 a can which is more than tuna costs, so....actuallytastesgoodman.jpg
Admittedly haven't had it straight from a can - my toasted sandwiches usually do a good job of covering up the fishy taste of tuna, so they could have done the same thing here. But they did taste better than tuna sandwiches. Similar protein levels too...give it a go.
You mean he was slightly less of a top bloke when you dressed well? Must have a hard on for the rough types.
Your work in a hospital?
These are $1 at Coles. Thought I'd try some as a substitute for tuna in my toasted sandwiches.
Bread (Toasted)
Garlic Butter
Chicken
Grilled / Melted Cheese on top.
Makes it taste better.
I remember we spoke of this at the last Garage Cafe SAU meet :laugh:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
