Took the day off work and I'm sitting here patiently waiting for The Thread Doctor to arrive.
Removing a snapped dump bolt from my turbo rear housing, and 3 exhaust mani studs from my block.
What are you guys up to today?
I'm at southern grampians volunteering by setting and catching bandicoots for research O_o
Dat corporate volunteering
lol no worse?
you're in for a suprise lol
its not even so much economy.
major PITA having to fill up all the time because of the small child sized tank..
that and the turning circle lol.
the only two faults i have with the car...
replacing the o2 over the weekend to see if it makes it a little better as the o2 looked as if it was all over the place.
currently 250km to a tank.. stock. fun. no
that's ok... i'm not worried by the small tank... also 250k/40l is about the same as the skyline and that's not tuned... it should use less fuel but by a bees dick
Yeh, it seems ok, i just think I'm worrying too much and giving it abit too much boot. But when people are saying they normally get 320k out of a 7 tank..
Well...
37 litres i filled up to be exact..
got 252.3km lol
apparently tank size is 48 litres
which is bang on correct for 320km to a tank lol
i've literally calculated how paranoid about stupid shit I am haha
Watching Sopranos re-runs and job seeking.
And sorting out my farkin coilpack issues.
coilpacks +1 :(
need some new puppies in mine too. but mine have been dying for a while LOL.
coilpacks + major = happy days
hopefully.
*soon*
+ 1
Coilpacks letting go after 160,000K and hitting 19psi today
All my bolts came out fine only took a few mins
Me got my car tuned at Chequered tunning today
Fuel economy is for pussies.
+ 1
lol no worse?
Yup noticed the fuel economy in the Evo wasnt that great
And the turning circle is crap lol
What'd you make Toby?
Guy in an excel was driving behind me this afternoon, taking a photo of my car on his phone. Were u mirin me Dezz?
Coilpacks were failing so atm 265 rwkw on 19.5psi with a boost drop to 15.5psi at redline
If I sort out coilpacks and boost drop trent reckons should hit 300rwkw
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
