What'd you make Toby?
Guy in an excel was driving behind me this afternoon, taking a photo of my car on his phone. Were u mirin me Dezz?
Yes
Took a photo once while driving of a sticker advertising 'hectik' hairdressing but couldn't get a clear shot...was disappointed.
How much for a men's cut?
Corolla, 400km+ a tank... :rofl:
That it...?
Staying in Hamilton. Wanted to try Royal Mail but schedule does not allow :(
Next time!
Went for dinner once - around 8... "Let me check, the kitchen is about to close" ffs, damn country towns
Toothbrush cleaning the engine bay - found a split in the tiny hose out of cyl 1 manifold position to the charcoal cannister..... pulled the spark plug all good on the colour.... gotta love/hate the map sensor based ecu otherwise would have been running like a bag of shit sooner.... think it's been split since I bought.
Fixed hose....PLUS - moooooooore boost earlier - goes well.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
