Yeh I pulled the orange lense out. Made a good difference..
Also painting the insides black and cleaned the lense..
Tony, Scott's plans are to get it running for now, but don't think he'll start till next year.. When he starts modding, I guess I will too lol
gonna do the same but i'm keeping the orange and doing the projector lens yellow
JDM33 is now on hold for an interstate buyer, so looking VERY likely to be driving away next week after 7 years :'(
340rwkw by 4000 rpm sounds annoying (in a fun as f**k way)
al's car is hard enough to drive let alone add 100kw by 4000!
because it's auto it requires very little throttle and just purs along < 2000rpm in normal driving and comfortable as love it
on another note, called that guy with cbr600rr but got voicemail :( did 80kg bench tonight :D
Edited by UNR33L
I thought about keeping the orange lense, then I felt like I was putting a chev badge on a Holden. It's an Evo 7, not an 8MR ... Even worse would be the fact they aren't even genuine 8mr lights lol
not removing something is not the same as adding something
EOTD it looks better so ima do it
Up to you. Dependig on the colour you'll figure out what you want to do. I thought it looked better with it removed on a white car, on a yellow car or something it would look better with it there.
Meh I like it without it and its my car lol. I'm not gonna do what others like, ill do what I like
garage ftw yo.
and on another note, its f**king hard to get filter paper in melb... none of the scientific supplies do over the counter sales, its stupid.
Bahaha, unless I need to go out that day! :(
I normally get lazy, wait till it rains and gets it wet... give it a quick going over with a microfiber towel... then go back inside and let the rain rinse it clean.
Ahaha, sounds nice and ez. Should get in on that finishing detailer spray stuff perhaps as well?
I need a good coat of wax before I can do something like this xD. Probs end up dirtier... always does!
Car has had its final tune. 280rwkw. 190rwkw @ 4,000rpm
Come at me Birds and Odium
Maybe not Leigh though :/
I'll race u. NA 4lyf. (Notrly). How's the power with actual driving? Still the daily, right?
So it begins
I hope you guys still have these when I get mine... :D
Who would have guessed you would REMOVE something orange on your car
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
