lol I should have stopped by, would have loved to see some f**kin tools doing burnouts copping a yellow sticker and a f**k off fine.
Saw Tone at Cold Rock though :)
Haha yeah that was a bit of a coicindence
I thought that but it was on the nature strip = public property so fair game no?
Even so how can you even defect an unregistered car :/
any of the headlight cleaning kits work the same, some are just more abrasive and take less effort / time
you can also use mcguires plastex or mother plastic polish.
you can even use toothpaste
no matter what you use, just use heaps and spend ages doing it.
lots of pressure is required too
Glassylite..
Hamish I tried the plastx and mguires and yeh it came up good, but only lasted a couple of days, the thing that's good about the glassylite is the 'nano sealer' to stop it from yellowing a lot longer..
The bepore picture is with plastx, and about 20 minutes of constant polishing on each headlight. 2 days and it was yellow again, and worse than before lol
This is Aaron we are talking about, he was getting a sore wrist after the 1500 sandpaper. lol
Pictures still don't do it justice.
Nanosealant for the rip.
FYP
By the way Birds, my daughter wanted to know if you were a little girl, due to your avatar pic. I said yes, the girl you met last night. :)
badd
in person the only way you can tell there is a cover on the light is because of the reflection..
i wonder how the tail lamps would come up? lol
Intradasting
I shoulda had a look at your car on Sunday
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
