Are you guys for real?! The Panigale has TWO EXHAUST PIPES! One added onto the end of another... how can anything be worse!!! And the second is such a dodgy job... ew ew ew. At least the other look like they're half meant to be there.
But really, who has stock exhausts anyway, you can't judge a bike on it's pipe. Should be chastising the owner of the Gixxer rather than the Gixxer itself imo :3
Which market got the shitty exhaust? My mates 'S' has the bottom exit exhaust
I got mine on Gumtree, 7 grand due to the previous owner not checking the oil and lunching the engine.
I just placed an order for a full Brian Crower 2.3 stroker kit with all parts to rebuild the engine and it only came to $3700. Including the machining I should be able to keep it under $13,000 total cost by my estimates.
Naice! Cheap as chups
What power you aiming for?
Just Japan. Because it's a European manufactured bike their rules aren't as strict as Japanese restrictions, as neither are ours. Hence why Jap bikes look crap all the time because they are designed to stricter rules. And why we can modify them to street legal pipes that improve the look immensely because they are actually a very different design internally.
If no one likes the gauge holder then where should i put oil temp/oil pressure gauges then?
DIN is not an option...
put em on the bonnet like all the cool kids.
what about the drivers side pillar?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
