Might drive through it for a laugh
you do realise that even if your car is stock they can defect / EPA you and it is YOUR responsibility to pay the fines and pay to have it cleared right?
fail laws are fail :/
http://actionshotcam.../news-and-blog/
$50 from Kmart.... anyone gain to be the guinea pig and try it out???
rob drydrek on the packaging is EASILY enough reason not to buy
lol was in jess' rx8 today...
and lol rob drydick is a dickead
just buy them from a fishmonger and learn to open them yourself fool
taste 11ty times better and guaranteed fresh (alive) - not to mention cheaper
opening them isn't that hard, it takes practise to get really fast and some can give a little trouble to the uninitiated.
At the buller cruise a few years ago i took up around 6 dozen live ones and taught a few of the guys how to shuck them... i remember basti getting it pretty fast
yeah i remember. all in the wrist. just like shanking someone :ph34r:
That's a bit racist
I'm waiting for GoPro Yellow edition
you might need to invest in a wide angle lens if you get the yellow. just saying
back from horsham / bendigo today..
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. sport bike = female magnet? pretty sure that never happened on the tard'
Edited by UNR33L
I'm guessing you didn't open the visor otherwise they would of sped off ey Leigh.
Got her number?
If not, the answer is no.
Yeah, not that it would make any difference had the clear visor on anyway
Got her number?
Yeah man, I got my pen and wrote it on my arm
Forked pickups for my rear stand
Nah I meant what did you order from Misty's that let you down?
I recommend Langham, haven't been there in a while but it's never let me down for buffet food.
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. Lee = female magnet? pretty sure that never happened on the tard'
fyp
Just a once off I think
Else I'm gettin me a sports bike
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
