Might drive through it for a laugh
you do realise that even if your car is stock they can defect / EPA you and it is YOUR responsibility to pay the fines and pay to have it cleared right?
fail laws are fail :/
http://actionshotcam.../news-and-blog/
$50 from Kmart.... anyone gain to be the guinea pig and try it out???
rob drydrek on the packaging is EASILY enough reason not to buy
lol was in jess' rx8 today...
and lol rob drydick is a dickead
just buy them from a fishmonger and learn to open them yourself fool
taste 11ty times better and guaranteed fresh (alive) - not to mention cheaper
opening them isn't that hard, it takes practise to get really fast and some can give a little trouble to the uninitiated.
At the buller cruise a few years ago i took up around 6 dozen live ones and taught a few of the guys how to shuck them... i remember basti getting it pretty fast
yeah i remember. all in the wrist. just like shanking someone :ph34r:
That's a bit racist
I'm waiting for GoPro Yellow edition
you might need to invest in a wide angle lens if you get the yellow. just saying
back from horsham / bendigo today..
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. sport bike = female magnet? pretty sure that never happened on the tard'
Edited by UNR33L
I'm guessing you didn't open the visor otherwise they would of sped off ey Leigh.
Got her number?
If not, the answer is no.
Yeah, not that it would make any difference had the clear visor on anyway
Got her number?
Yeah man, I got my pen and wrote it on my arm
Forked pickups for my rear stand
Nah I meant what did you order from Misty's that let you down?
I recommend Langham, haven't been there in a while but it's never let me down for buffet food.
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. Lee = female magnet? pretty sure that never happened on the tard'
fyp
Just a once off I think
Else I'm gettin me a sports bike
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
