A bird just shat on me.
While I was driving. Not one bit of shit on or in the car. Just me.
And where you ask? Side of my fkn face.
Fkn birds
Good work bird
haha, a bird shit on the bouncers arm last friday night, as he extended it to wrap a band around my mate's wrist...
they must be perfecting their aim.
Edited by kaitoukid
Also, f**k this new youtube layout. It's like they hate my eyes.
EDIT:
Got this to centre that biatch: http://userscripts.o...s/review/153584
Although if you use chrome, copy paste the script into a text file, save file with extension .user.js, then drag into chrome extensions (spanner -> tools -> extensions) to install.
But still so white *_*
Oh well. Content nao. Just some casual minor rage @ left alignment.
Edited by kaitoukid
haha yeah I did but they fill up so fast (/subtle)
Jamie I drive a falcon it just sees A - B and sometimes princes hwy no track days for me :P yea but i'll help time cos I'm a nice flamin mongrel
LOL!
Soo hows that car of your Jamie...
All good back to factory specs :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
