I don't see how that's possible lol...his car got hit on the driver's side, which means he would have had to reverse out of his driveway onto the other side of the road for a car traveling in the right direction to hit him, unless it lost control itself.
Re-do the mission and talk to the NPC's.
Sargent would have explained the traitor after the mission, from your first round.
Ah k. We got kicked out at the end due to being accused of hitting a zombie with a gun. So never got the close out as you've mentioned.
Don't tell me cause birds will hit you haha
only a few days, 30th Jan - Feb 3rd.. No Idea where staying, the missus has organised it with her dad, he owns a couple of apartments up there in some building.. mainly to go see her Grandma whos ill.. but yeh wanna do scuba, but cant imagine myself in a wetsuit.. beached... Also her cousins have access to some jet skis up there.. will do that too!
LOL
when I scuba'ed in Fiji water was warm enough that I jsut went in tshirt and shorts, no wet suit.
same as boracay in the past couple weeks.
Vanuatu I was diving to 40 meters to suited up for that.
for an intro dive you will be doing 9-12 meters so not much cooler than surface temp.
sell car to gen y...
nek minnit...
sucks after the work you put into into it.
thought you were keeping plates?
plates being sent back now
Are you doubting him? The guy is able to count to potato!
Yeh I think it's wet season in jan/feb, so we'll have to see how it pans out. Been wanting to scuba for ages so regardless will be doing that.
if you want to borrow a decent underwater camera buzz me a couple weeks b4 you go and you can borrow mine:
from Boracay
cohhh..
will do, hoping i get the Hero 3 before then(which I should) that thing is amazing under water! but if I dont, will call you.
cheers man!!
how deep are you there?( insert sexual inuendo here )
Am I gonna need a different tow hook setup for my 33 for Sandown? If I do need a tow, my front bar is gonna get destroyed right?
I'm assuming its one of the Support Navara things with a towbar strap and a carbina on it?
She'll be right. i got towed with my stock hook under the bumper bar and I was fine
Toby when you upgrade?
I just took delivery of it!
nek minnit...
Be interesting to see how it plays out with insurance. I agree with everyone here that his story smell like bs
cohhh..
cheers man!!
that was about 9-10 meters
to give an idea
1 meterish:
10ish
20 ish
just over 40 Meters
as you can see the further you go down the harder it gets to see..
the best diving I've done in fiji was in the 8-15 meter mark, lots of bright fish to chase, and your air lasts longer,
(at 20 meters you suck twice the air of 10 meters)
the go pro won't be the best cannot focus in on small details as much as you would like and no flash, (needed often) and no zoom.
oh and as for parasailing.
I treid that as well, but I fkn hate hights and did not like!
to give an idea
1 meterish:
10ish
20 ish
just over 40 Meters
doin it.
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
