Ferken...
Still need to throw the decat on, see if my Bosch 040 still works so I can swap it over on the day if required, hook up the oil cooler...
There's not enough time in each day! :P
yeah I will prob be doing a oil and filter change at the track, unless I get some spare time fri night.
that said I will also prob only do 1 session or so b4 I give up and just do passenger laps
also will probably do 1 session and just jump in with others..
standard brake lines wont last more than 5 laps i dont think..
This weather better pull its head in or Saturday may be interesting
Do you even enter brah?
Usually only 3 flying laps each session with the Wrx club, She'll be right
In saying that I'm booked all day giving people passenger laps so won't be going 100%
i plan on getting there early to get a garage ... if its 28 degree's, i sure as shit dont want to be standing outside.
Book now if you want a garage
why does it matter what colour they are?
its just going to get covered in brake dust and dirt and go black grey brown anyway.. brake lines are there to help you stop, not for a wank factor...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
