Oh yeah
Car found dumped and broken down in Emerald
Guys who stole it asked the neighbours for help when it broke down haha
Bloke got caught red handed?
Does that mean you get it back now, or what?
Of course, not insurance payout yet.
Good news? :ermm:
Hrmm no GTR i spose haha
WIll need to wait a few days before I can inspect the car
CCTV + speaking to neighbours + fingerprints
Hell get caught eventually
Oh yeah
Hooray! Good to hear he didn't set it on fire as most do.
He probably put 91octane in and was gunning it on your 98 tune :/
What a moron.
Steals car, drives it as if it's his own, repeatedly in same area, AND asks neighbors for help with it?
What an absolute amateur. Hopefully the car isn't in to bad of a shape mate.
I dunno, I guess it would depend on your emotional attachment to the car.
I know for me if the car was still Mechanicly and it'd only be taken/stolen by joyriders if nothing was wrong I'd want it back. Plus, I'd loose a fair bit of excess if it was stolen.
So I thought having a stock standard Evo would stop all the cop troubles
Nek minnit, pulled over by 3 cop cars and about 7 officers
"This is a random check" "we thought your number plates were home made"
Dafuq?
Let go with a merry Christmas..
lol @ above
I've seen homemade like cardboard plates on trailers they never seem to get in trouble
Went through breatho last night cop was a good bloke actually obviously not like they'd look over my car or whatever but was just a normal human for a change
Edited by alr33x
Nah they were fine. Checked the hooks and said they were secure so its fine.. Just thought the plates were home made.. I mean its Dandenong, my car was probably the only one that hasn't got home made shit on it in the whole suburb.
But the cop was fine. Polite and all said hi to everyone in the car lol. That was it.
yeah, but the USA plates do look pretty different, even if the letters and numbers are correct.
I dont' mind being pulled over for this kinda shit, it's how you are treated once pulled over that shows whether they are a pig or a cop
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
