That Honda looks fkn gay its a family car not a touring car
It's tight as - but then you see the price difference and almost say makes sense.. Not only that its farken hard getting weekends, sat especially as good places book out years ahead
If you fail to plan you plan to fail.
Yeah I get what you mean about the price difference though, that definitely does make sense. I dunno, if it was me I'd rather fork out for the weekend, makes it easier for guests too. The thing with weddings that really pisses me off is when expat couples decide to have a wedding overseas. Wtf? Seriously have the wedding in your HOME COUNTRY.
I plan on have my buck's week (not weekend) overseas :P
I hate people who go o/s weddings like you live here don't expect me to fork out $$$$$ thousands on air fair accomodation etc.
Just take a photo for me.
/tightasse4life.
For me non Saturday weddings are great in my business lol
if its changi village, then, go for the chicken horfun, i think there are two stalls next to each other, both are good.
nasi lemak is a night time affair though.
but at changi airport itself, the staff food court in terminal one has some goodies too, most notable is the bean curd dessert thing. we call tau huay, or tau foo fah in hokkien and cantonese respectively.
who says he wont be there at night lol
Is it just me, or does this kinda look like an EVOX? Must be the wheels...
it's just you
Bahaha, the important news updates! XD.
I should go grab some... But then again ate so much crap yesterday (kfc double down... Missed out last time so figured should it try it this time... Sahh greasy :P)
Also in other news I think it's the usual supercheap 20% off most stock tomorrow... Might to grab some headlight restorer kit / PlastX etc
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
