yeah it doesnt worry me cos its my dads
he loves recording free to air stuff so he can put up with the ass features =)
ive got two wd tv live's in our house
bulletproof and plays every movie
ive even got two cisco switches now so its a pretty good setup
14 active ip's in my house =)
About to watch The Hobbit...
Watching at Doncaster shopping town... A note to any low brahs... Go up straight to multilevel. f**k the area outside the cinemas. Speed bump + humps are like freaking spikes in NFS, dat scraping :(
Wait till you go down the exit ramp bro. Scrapes like a mofarkin hustler.
Always get scared of the ramps in the Kings Way carpark at crown...never scraped once though. Deceiving.
Wilson's Parking on the other hand...owe me about 5 or 6 front bars.
Yeah, it's bad up there. Hadn't scraped on any of cars I now have and had.
Good thing I don't have to park all the way up all the time since xmas is over - easier to get parking closer to work.
I'm not too far from franga maybe I can pick one up for you?
Let me call them directly tomorrow and check if they have it, then I'll collect it from you at go karts. :thumbsup: That reminds me, i need to pay for that!
So.
I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee"
and i'm going in full formal, is that a right decision? tie blazer and all dat.
Intern at HR company hide all peircings and that butterfly tattoo.
but in reality your going for a job at a i'm assuming professional company, you should suit up as ther a good chance that what you will be wearing on a daily basis.
So. I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee" and i'm going in full formal, is that a right decision? tie blazer and all dat.
http://youtu.be/6Dtn4kP7lrA
So.
Is it a city job?
Suit up bro
Like Martin said likely you'll be wearing that everyday
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
