can always spray them gloss black like I did, stands out less than normal
Yeh I should've done it when i had the front bar off, so ill take the bar off when I glassy light the headlights again, and spray it then
Yeah will have to put up with a Autobarn run..
(and not crappy parts autobarn..the fun one)
So I've done Good wood once b4 and it is insanely good.
and done the ring b4 as well which is hella fun.
the 24 hours is a little different, but not sure if I can could watch one race that long esp solo
but it is one of the few things left on my cars bucket list.
24 hour sounds boring as bat shit
+1
May as well go nuts in unrestricted Autobahn, racing these DB Bahn trains. I was mega jelly when I saw these BM's flying past while the train was busy being slow and backwards (no idea why).
TONY...
Car came with:
- Ground kit
- Front Mines 3point Strut bar
- Ralli-art rear strut bat
- Cusco front subframe thing
- Blistien coilovers (with cusco Camber Tops)
- Short Shifter
- HKS EVC
what i've done:
-X3e Front pipe 3"
-Xforce hi-flow cat 3"
- Apexi n1 evolution 3: cat back
- X3e LICP
- C\F lip extention's from John@rota
- White LED interior and numberplate lights
- Rubber Boot Matt (clark Rubber)
- Rolled Rear Guards
- Blitz Pod
- C/F Gear knob
- New battery
- Slotted rotora all round
- X3e Street Pads all round
- ASI Radiator
- E8MR BOV
- Walboro Fuel pump
- HKS Style front lip 2tone black white
- e9 Rear Bar
- SSR Sp1s limited edition 18x9.5+12
Update:
Upgraded to e9 turbo
Kando Dump Pipe
Kando Fitting Kit
FIC 1050cc Injectors
Silicone Intake
and had burnzy install and tune it all.
229kw on 22psi
He wants 21k with RWC - compression test was pretty decent (cant remember exactly but he has it on vid)
I offered him 18k as that was all I had... he didn't take it but has since messaged me asking if i still want it...
car is as is but without the professors
DOOOOOO EEEEEEEEEET!
princess hwy drags is my pick
i lol'd
Basing myself out if Stuttgart for a month
one of my best mates lives there and can show you around etc... tell me when you are going and i'll word him up
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
