sif buy a jeep.... dont' you have youtube? those things'll kill ya :P
lol thought that was just new ones...
Jeeps are rated well for off road capability, interiors are a bit cheap like sitting in a plastic bucket
not too fussed about interior quality/luxuries
How reliable are older jeeps? Say early 90s
Obviously they're no toyota landcruisers but how do they compare? Also, old cherokees ever come in manual?
Xoxo <3
Which model specifically and for what use? A girl I knew, who practically stalled everytime she moved off the line (dat cringe when 300rpm launch), managed to get her daily driver Wrangler to 250,000km before it developed engine rattles.
Just laughing at the fact that they actually have to cut the bonnet, to make it function.
Or people just buy the bonnet bulge for looks.
ignore him... he's just that asian kid from "From Dusk Till Dawn" trying to get another 15 miutes
LOL! Fucking this guy.
well clearly you are going to have to cut the bonnet for a vent to work lol
Was more so pointing out the fact that the stock bonnet has to be modified to make it function...
Where as you buy a JDM car, like an EVO, there is already a functioning vent.
Or remake a whole entire bonnet, like the Nismo Z-Tune bonnet, for example.
What's the point in the bulge though?
The bulge goes back to the oldschool SS's where the engine didn't actually FIT in the engine bay
Edit: It's either purely for looks (Surely the OEM bonnet wouldn't overheat the engine, so it requires a vent for cooling) , or it is to accomodate a Walkie Top mount supercharger kit or some crap like that...
Edit 2:
WALKINSHAW PERFORMANCE POWER HOOD SCOOP SWB
The Performance "Power Hood" Scoop has been designed in the heritage of the original Walkinshaw Commodore from 1988. The Hood Scoop is the perfect sports accessory for the new VE range.Very aggressive appearance.
Looks like it is mainly visual only...
I don't mind the E2 Intake Scoop though...
http://www.walkinshawperformance.com.au/wp/au/products/models.asp?content=ve&cat=exterior
wut
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
