in other news...
FedEx should be bringing my ipad mini case today, and my ipad mini and nexus 4 on Monday. Such excitement waiting for deliveries! But then don't wanna leave home in case you miss it!
in other news...
That's why I always get stuff delivered to work, no chance of it being missed :P But then it sits on your desk and you have to resist the urge to play with it until the end of the day...
Got some 2nd hand injectors delivered once... still full of petrol... People in the office were like "Can you smell something?".... "Nope?"
DENY DENY DENY!
You need a manicure and a manual car. GTFO.
Delivery attempted; recipient not home MELBOURNE - AUSTRALIA 09:49
Fail.
Ah well, not like you could use a case over the weekend without the ipad anyway :D
DENY DENY DENY!
Fail.
Haha if only I worked FT!
Damn it, I missed my delivery FFFFUUU. They came at 10:52am apparently. Before I even posted that this morning!
I left the tag that says "PLS LEAVE IT AT DOOR" just in case this happened... but I dunno what time I did. It was definitely AROUND 11... have a feeling I was like 5-10min too late or something. URGHH. (Yesterday they came at 1:15pm so I thought I was all good!).
Haha I got it for my dad (his bday is on Sunday). Was going to have to give him the case... and tell him he'll have to buy his own ipad (since that's not coming til Monday... but he doesn't know that)
But now I have nothing to give on the day gg.
Looks like I'm not leaving my house Monday.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
