you raise a photoshop with the most played out rims of the last 2 years?
epicfailphaggot
And that horrid factory kit..
I'll give you that it did look good when white. Although his engine bay still is, that must be some consolation?
Nah that's just lazy.
How ya legs Leigh?
feeling alright atm, just got back from a ride and tested gopro out, so dark through the hills hahaha
edit: I'm sure ill feel my legs tomorrow don't you worry child
Edited by UNR33L
Motherf**ker...I was around when AP was rocking a Winnie The Pooh keychain and a hot gf. Basti had a car blacker than him...James Kung existed...Kris was cool...
this never happened. noob
AWKWARD
they broke up for a bit, so you are half way right. which is just another way of saying completely NOOB
So what causes those wobbles? Rears sliding then catches grip?
/noobbikelineaustralia
Wind, road surface, suspension settings...lots of things. It originates from the front tyre though. Something about the front tyre oscillating on the turning plane, starting small and amplifying very quickly into a wobble with little warning. Steering dampers come factory on a lot of supersports to reduce or prevent it.
Also called a tank slapper because the handlebars literally go from full lock left to right, sometimes contacting the fuel tank.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
