here ya go phag, some quick clips from the first run, me following ur mate then me following you, go pro hero 2 actually pretty decent quality
makes your arms look really long
Brings me to this
And makes me scared for you, birds, and the other dude when you overtake all the cars around corners like that. I dunno if it's the go pro, but fk I'd be too scared
hah yeah good thing I cut out my overtake on that black commodore then :P if anything I reckon the go pro takes away from the speed
I dunno, adrenaline sometimes gets the better of you one thing to consider also is just how quick the bikes pick up speed from a 80km/h roll little twist of the wrist and you're past the car already
Edited by UNR33L
Yeh and I also realized that the lower the camera is to the floor, the more realistic the speed looks..
Yeh I don't know I would love to get my license but I think confidence will get the best of me and I'll end up killing myself
At least get your license, see how you find it that way you've got it.
Risk also depends when / where you ride I reckon, peak hour to work a few times I've done and is way more dangerous, heaps of cars out.
That being said the other day I almost got cleaned up, I'll see if I had gopro on, remember when I was raging at the car birds basically he overtook someone then they just turned into me thinking there was only one bike, actually doesn't even look bad on video :\ dam the gopro and it's wide lens!
Edited by UNR33L
lmao, i took the mazda daily on some jumps. and the work ute on some gravel roads, 2nd gear clutch kicks haha
that said.
time to start stock piling parts.
looking into brian crower kits...
Yeah definitely, Watching DECA and Sandown footage is so slow and boring compared to actually being in the car... Especially if the camera is mounted high on the car like the roof (or helmet in your case)
Showed my dad some DECA footage once and he was like "Oh, I thought you'd be going faster... " /dadburn :(
totally... how slow is DECA footage :/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
