And makes me scared for you, birds, and the other dude when you overtake all the cars around corners like that. I dunno if it's the go pro, but fk I'd be too scared
You get caught up in the moment and stop thinking about safety, follow adrenaline and obey instincts etc. That's the main thrill of riding a bike, pushing the limits and getting out of it alive. 99.9% of the time you'll be right when making those decisions, it's the .1 that will get you one day. Very easy and quick to overtake on a bike though. The biggest mistake I make is too much corner entry speed after overtaking and then I have to slam on the brakes or I end up overshooting the corner. FYI that was a pretty cruisy ride through the spur, we weren't going that quick compared to some of the other riders up there and the gopro does make it look slower. I feel so safe when I get back in a car hahaha.
so having a look at the album that the above phaggotry come from, it appears the new thing i taking pics of slammed/fitted cars without tyres on the rims...
since when is it cool BECAUSE it's inconvenient?
fkn losers
Yeh well after we Learnt at sandown, I have a bad habit of overshooting corners. So I think a bike is probably going to go on the list when I'm ready to die
fkn losers
Brings me back to an argument I had with NS in the fitment thread, and I told them they are better off running 195 30 16 on a 18x10"
Close enough. I win
fkn losers
could do with lol's post link
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
