got moonface superlap tie rod ends delivered today.
ordered them last wednesday via jdmconcept and they imported them and got them to me in 1 week!
very happy with that!
i couldnt if i tried lol probably book in for racepace when i have everything as they did a good job last time, then ill take it to either shane or someone for a decent alignment.
i still have alot of parts to come - the moonface tie rods which are needed for the tie rod ends are still on the way
No power mods?
not at this stage, i have to admit ive always done handling mods instead of power - though i have a big list of parts im working towards, turbos and ecu are pretty high on that list too :P
Ok cool!
Yeah Shane does good wheel alignments.
Need moar powah.
Just sayin
hmmm.... handling and power mods, I seem to do one of each and just take turn.
Did you do anything about it? Contact the seller and rock up?
Nah, was told by the cops to not contact them as they will and not to do anything else.... was tempted to rock up.
btw anyone felt weird or naked while sau server was down??? Maybe it's just me.
yeah i would load up sau and realise it was down and was pretty much 'f**k what do i do now'
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
