Fuck yeah!
Anti-Lag system is epic!
You should Anti-Lag your EVO!
will do when i tune it for the bigger turbo... but it's not sometihg you use often unless you have a specific desire to break shit
:laugh:
Just take it easy and launch only when needed to.
they disturbed a LOT of people last night
was meant to be a c130 doing a fly over on stkilda beach releasing angel flares:
pic related : c130 releasing angel flares
however at the absoulte last miute they post someting on their facebook page saying that there has been a technical difficulty with the plane and that anoter c130 could not be organised, but if you wanted to see it then just go to the airshow.
what do we have like 1 c130 in vic and that's it?
IMHO it was a stunt designed to get people to pay to go to the airshow and was never going to happen.
I'd bet they never even got the appropriate permission to deploy the flares
actually we have none in vic
24 based out of NSW but many deployed supporting our troops and some shut down as we selling them to indo.
woohoo for wiki
if i had the choice between cars and planes it would be planes for sure
i'd buy me one of these bad boys in a heartbeat
unfortunately I don't have $2 mil odd to spend on my hobby :/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
