Also, got a tune last night....
My tune history has been as follows...
260rwkw
250rwkw
244rwkw
223rwkw
Timing up high is like 8 degrees :P Power FC is pulling out all the timing because the turbo is making super heated air... We think I've got a leaking Intake manifold gasket (the middle one) so the turbo is working so much harder than it needs to to make 18psi...
Then I'm hoping to return to that responsive 260/270rwkw goodness
Twice in one week... Both while I was parked and not even near the car.
Great.... Just... Great....
Edit: Aaron, your people need to learn how to drive...
LOL you're copping it bad man.
Curries? What they say? Hahah
She tried to blame it on me for parking where the Body Corporate doesn't like people to park... and then started screaming at me about Karma because I didn't apologise and accept blame for her reversing into me.
I don't actually think your genetics make you a bad driver... but well, you did spin your car right in front of me on turn two at Sandown... ifyouknowwhatimean...
Lmfao are you somehow trying to say that Aaron spun his AWD Evo 180 degrees going around turn two at Sandown raceway on a warm-up lap???
Too low, suspension travel, and h-pattern on gear knob
No fine or roady, and a month to clear. He was mirin my neat engine bay, I think that may have had something to do with it
State HWP it says, got done on Beaconsfield Pde
Pics of said tidy engine bay plz.
Anyone have exhaust manifold studs for rb20/rb25
Have a new set and a used set, need the new ones though.
Edit: Actually used ones are incomplete and a couple were snapped.
D22 navara turbo failure
cousin calls me around dinner saying his car broke down at mt disappointment.
drive there, he starts it, WHEEEEEEEEEEEEEEEEEMMMM white smoke
pull off the elbow bolted to the inlet.
met with this.
worst. turbo. failure. ever.
were worried it might have grenaded itself...
got it towed to a mechanic.
asked him to check every little bit of the engine
If the motor survives this, I'd be really amazed by it.
The amount of stories about ZD30 grenading is HUGE!
met with this.
That's a disappointing end to his day
YEEEEAAAAAAAAAHHHHHHHH
Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Since we are talking genetics.. I'm surprised you haven't been in more crashes...
What with not being able to see over the steering wheel..
:P
lmao we were ripping dissa jokes on the cb when he was in the tow truck.
all quiet from his end, and then all you hear is, SHUT THE f**k UP
Yeah i do lol
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
