oh very nice, ~330awkw coming at you! :P
wonder if you could get like 350 with e85?
Sort of had a run with a 33r with racepace built and -5s the other night, when he was next to me gearbox went in 3rd and such a bad noise :( had sau stickers but not sure whos car it was pretty sure ive seen it before though. Maybe Ash's old one? shit didn't sound good :\
Yeh that was me mate, Ash's old car. Sounded fkn brutal, I think it's in a million pieces inside. None of the gears work properly apart from reverse.
She was going so well that night too, shit happens!!
Thanks for stopping by mate!
Fuaaaaarrrrrrr, how much that costing you roughly?? Come get em installed at work! .....or I'll do it ;)
I paid about 2.5K for all that. Need to grab a few more parts still - and have some more on back order hopefully arriving late this month.
Yeah it will be coming into your work for everything :P
Probably a month and a half away though.
I might have a gearbox for sale shortly :P
yeh looked like it was pulling hard! hopefully not too bad to fix it up.
decent night anyway heaps of tuff cars
Yeh it's been pulling like a train since the tune. I'll find out soon how bad it is, I guess all the abuse has caught up with it.
Yeh good night but wasn't fun waiting for the tow truck next to the shit farm tho and being visited by the police lol.
Got a free tow tho thanks to my mate :)
lol'd at smiley face over Cass
To the people who requested it get posted: strong unaware
Standard box I assume? "3rd always goes 1st"
It'll have every tooth missing from the cluster gear; new gearbox for you. Unusual not to have 4th left over though. Lucky second hand GTR boxes are cheap!
lol what'd you say to the cops? I'm just waiting for a mate?
Ah that's good at least then, bonus is it wasn't the engine!
what did the cops say? lol
Best chick cops we've ever come across, didn't check anything had a laugh with them and they left lol.
May I add one was pretty hot too :)
I know the 3rd is the weak link, it lasted for 2 seconds before letting go. It is a standard box so we'll see. It sort of selects 4th but feels really strange it doesn't pop into gear, I really have to force it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
