Also day off for me today. Just had to skip some lectures ;).
Woke up excited for Top Gear ep... hadn't finished downloading. Extremely disappointing dl speed dunno what happened. Torrent had good ratios too... Oh well, no matter. Will be done by the time I come home from gym :D.
I downloaded what I thought was the part 2 of that episode only to re-download part one - worst part was I redownloaded the 720p one.. so 2gig x 2 =/
f**king need to read...
Haha, who watches in anything less than 720p anyway, m i rite?!
But I know dat feel bro. Has happened at least once or twice to me as well... Worst is probably when you sat down to finally watch it... and now you have to wait for it to dl over again, and you missed the perfect time! ;p
Ill download it tonight over LTE through the iPhone. Gotta love 4g speeds when traveling.
Things to do when you're traveling alone for work?
1. Gym
2. Eat by yourself forever alone in the restaurant
3. Furiously masturbate to midget porn
4. Download top gear watch and catch up on sleep
1. Gym
you need to go to more interesting places then...
Yeh this job doesn't have the best travel locations but hey it's still good to get out of the office! Saves a bit of money too being all on the work card
1. Gym
Does your manhood feel big when you watch midget porn?
Is this the 11k 32GTR?
Turn out to be f**ked?
9k which I suppose isn't as bad, but still.. when you're earning under 20 a year it's a big hit :(
What happened man?!
Long story short, this chassis is a nightmare, you know all those stories you find on the internet of cut and shuts and you go "nahh that never happens, just a couple here and there thats it"... well, yeah. My dumbass fault for not having it checked properly and you wouldn't believe how disappointed in myself I am but the only thing I can do now is find another shell, get it checked by Stateroads and hope for the best, then try and sell a roadworthy 32R and recoup my losses, or keep it and build it insane. Good for my reputation as a mechanic as well huh :P
ahh seriously =/
damn...
its not repairable at all? or just cost you much you think?
ahh seriously =/
damn...
Well essentially this bodies been cut in half and welded on a new half :P So it'll never ever be as strong as factory, had a body shop even say it was done SO BADLY that there's zero structural integrity and if you got in an accident it would either fold in half, or completely split. Guess that's what happens when you don't do your research and buy without a roadworthy.. Never again.
You know what they say, if it sounds too good to be true it probably is.
I'd be burning the cvnts house down for selling me a piece of shit
Something my dad burned into me as a young kid and I'll always remember, unfortunately I forget it in the moments I need it most.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
