Are there any major (or minor) differences between the FC Hako and a Datalogit?
From what I understand:
- Hako has 2 analogue inputs; DL has 4 (for wideband O2 sensor etc.)
- DL comes with it's own software
- DL can run hand controller at same time (no idea why you'd need to)
- Hako is $140 cheaper
- Hako will work with all softwares, not just FC edit
Don't need the extra analogue inputs unless you're hardcore into tuning...though you could still do this on the Hako with wideband and EGT sensors. I only wanted something that could load and save maps when switching fuels, so Hako it is.
Steak and BJ day today
I'll probably have chicken for dinner :(
Would it be awkward if your mother cooked steak for your father tonight...awareness not always a good thing.
210kw at the hubs, 19psi, 11.5afr
Exhaust cam retarded 8degrees
Good to be back in the 200kw club
Was tuned last night in the heat and intake is being restricted. (Dat intake pipe)
so you specified hubs because???
Have used both...
Hako is the way.
USB and cheaper. just need someone that has Datalogit and is willing to give up the software ;)
also it is nice to be able to run the HC at the same time so you never have to unplug the shit... just chuck in computer and away you go... other than that, no advantage
Have used both...
Hako is the way.
How difficult is it to save your existing tune to laptop and swap between maps?
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
