If its just for switching between two tunes, I'd be getting an ECU that supported dual tune storage... Or buying an extra PFC (ECU Only) and just swapping it over while at the servo :P
? Trent has a hub dyno which will give different results to roller dyno. (Due to less variables - slip, tyre pressure, temperature etc)
no... no it doesn't. results are within the same range as different roller dyno's
How difficult is it to save your existing tune to laptop and swap between maps?
like opening and saving word docs
lol Leigh might have something to say about hub vs roller.
Awesome, can't wait...though with any luck I won't need to switch tunes often at all.
lol not gonna get into this again.. but a certain supra made 430 somewhere and 348 at chasers dyno the other week, i beat it :D
all dynos are different, who cares it just means you go to the same place when you get work done to see the difference on power curve.
I can have up to 3 tunes on mine, So good for swapping from e85 to 98 and a valet tune :D
Edited by UNR33L
I think what man of beard is saying is that there's also differences between roller dynos at different shops, hence running on a hub dyno will also have the different calibration to a roller or another hub?
All dynos are different. I don't think hub vs roller has all that much to do with it
Spend a few $k and get a Octane Sensor and an ECU which'll let you flex the hell out of the fuel with anything you like.
Half 91 octane and Half diesel.... Will make Nick so jelly :P
For an R33 GTS-T that I've already over capitalised on...this makes lots of sense!
Haha not really, 91 is still more expensive than diesel atm LOL
More variables are at play when using roller, can't deny that. However the magnitude of impact of those variables on the output is debatable.
Cisco IP phones, you can select background.
unless your draconian sys admin locks it down......grrrr
I tend to change peoples ringtones to the Saxophone tone (if you haven't heard it, try it out LOOL) then lock the min volume to 15(which is max) and watch them rage :P
That said, a lot of those variables are set into the program and a Correction method used to make different types of dynos, temps, diff ratios, pressures, etc read "the same" as each other.
Never works out that way though.
In the end of the day:
If you want to compare one car to another, you put them next to each other on a track or drag strip.
If you want to compare your car to a previous tune, you do it on the same dyno and look at the graph/numbers.
I learnt real quick that numbers mean nothing, especially peak power figures. If you've got no midrange, or torque, you're going to get raped by that bodykitted excel golf with frangipani stickers teh lowz.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
