SO car was written off but not put o the register..seems strange.
Repairable Write off...
Cheaper for just car insurance to do a write off payout than fix it (properly).
Thus why this sale is clearly dodgy, there won't be a lot of change from $9,000 o.n.o. if it was fixed properly.
I think it doesn't have to be on the register if the car's over 15 year old?
That could explain why it isn't on the register...
WOOOOOOTTTTT MY CAR IS READY!
Time to go to the panel beaters and pick it up... Need to get there in under 50 minutes or the place will be shut... Waiting on a taxi to arrive now *impatient*
I've already called him saying I'm interested... Waiting on a call back... Will go and see it on my way home if I can.
Called him again just before... I'm going to go see it tomorrow... with Matt...
Shall record the encounter for the wasteland lulz
So... my car had a camry reverse into the middle of the passenger door.
It went into the AAMI assessment center on Tuesday Morning last week (19th)
It was getting a new door, and bring resprayed at a place Monash Car Center on Princess Hwy
I get the phone call that it ready to come pick up tonight.
Went there to go pick it up and it all looked good. the paint colors matched and all was well.
Car was locked, so couldn't open the door.
Accepted the car, drove it home and on the way I noticed a "few" issues.
They've swapped the inner door panel, speakers, glass, etc into the new door. The tint on the glass is scratched quite badly and is peeling (like inch long sections peeling off)
The power mirror does not function at all.
The power window functions intermittently, I'm thinking a wiring connection issue.
The panel gaps are different from the top to the bottom of the door, it varies by more than 2mm from top to bottom.
Letting the door swing shut by itself, it stops with 10cm to go.
Once fully closed, the top of the window looks to be about 1cm lower than it should be, so it doesn't go into the slot where it should go, instead it hits the bottom of the fat rubber bit.
Honestly, how the f**k can a place f**k it up so much... *sigh*
Gonna call JCI tomorrow and rip a new arsehole out of this joint.
2mm panel gap on a 15~ year old car...uhoh lol
Who could even notice 2mm other stuff sounds fair enough though. Panel beaters would have given zero fks they are useless pricks
Edited by alr33x
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
