Aaron. We barely half way through. If u come now. Still tonnes of food!
And there is no guinnea cops now!!!!
Good wine hurr too.
We just doing stuff bit by bit.
i do.. and i cant, already in bed.
i fkn hate you both. if he had told me 15 minutes earlier i wouldve been there!!!
Pshhhhhhhhh. Not dedicated enough. LOL.
But the guinea cops are coming back tmr for good.
Leigh next time you dive into a pool, drunk or sober, put your hands out in front...better with broken wrists or hands than Christopher Reeves...never go full Reeves.
Hsv releasing supercharged v8 soon
LS9? Would be more power in stock form than Leigh's car modified lol
Would buy.
wagyu burger.
and hamish, need temp controller for sous vide, was thinking of building one, but serioulsy.
no you dont, all you need is a thermometer, a straw, zip tie freezeer bags, hot water and an esky ;)
I sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
Would buy.
Nah, would be less... even with the capability to have that much power they will provide a detuned engine that can handle any fuel that idiots put in it, and then increase the output by like 5kw with each new model
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
