no you dont, all you need is a thermometer, hot water and an esky ;)
sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
Nah, would be less... even with the capability to have that much power they will provide a detuned engine that can handle any fuel that idiots put in it, and then increase the output by like 5kw with each new model
What kind of temperatures do you need to keep it at? Could you use one of those home brew kits?
no you dont, all you need is a thermometer, a straw, zip tie freezeer bags, hot water and an esky ;)
I sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
http://www.carsguide.com.au/news-and-reviews/car-news/hsv_supercharged_v8_tipped_to_top_w427
I cook most meat at 58c as per MY digital thermometer, and it comes out perfect every time, although my thermometer is pretty mangled as I have dropped it in the sousvide bath about 10 times and into a pot of 175c oil whilst deepfrying...
I usually get my steak from the vic market, leave it in the fridge until dinner and then throw it straight in a HOT griddle pan for like 60 seconds on each side to get some caramelisation on there, then throw it into some ziplock bags, suck out all the air with a straw and lock quickly.
drop it into the esky with the bag jammed in by the lid to hold the meat near the top of the water. set a timer for 45 - 60 mins and go watch tv or cook the other dinner bits
come back an hour later and chuck the bag on the bench to cool a little. and let the protien strands relax
cut the meat against the grain and throw on the plate with whatever sauce and sides I have made.
100% perfect medium rare rump steak that is as tender as all hell... every time
even the 427 would have only been say 300-320rwkw TOPS
I dont think it will be beating leigh's 370rwkw in a hurry, and it will be the TOP model @ $100k +
these are only guesses ofcourse
Also rwkw != manufacturer stated fly kw...
427 cubic inches = 7.0L
Bitch plz I could make 320rwkw with a few little mods to my little 2.5L ;)
mmmm but jelly of dat torque and power band... Super charged dyno graphs are boring... may as well go look at a wall, it's almost as flat.
inb4 leigh invites me to prinny...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
