such a catchy song and well done too.
Tried all afternoon to remove the turbo pulsars oil filter. Its been relocated because oil cooler so got plenty of room but wouldnt budge. Bought a strap oil wrench and it just stripped the paint off of it. Its mounted facing the ground, so screwdriver + hammer method is a bit tricky. farken kents put it on stupid tight.
checked spark plugs too... 1500kms and 1 track day old: black. A better tune and better injectors should hopefully fix it.
It runs PowerFC for the guy who was wondering (cbf quoting)
if your not re using the filter
jam screw driver throught high up and twist...
sorted
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
