Haha I went to Vermont coles too! But I went to the one near Bunnings. Can confirm it works also.
You're all welcome brahs!
That's the one I went to. Saw Indian dude, was like yeahhh he won't even glance at it; just wants to get his shift over and done with.
Was reading on OzBargains...few people getting knocked back at some servos?
Haha I cheekily asked him if I could stack it with my 8c discount. Was a no go though :P
Lols yeah he barely glanced at it. He probably knew it from yours a few minutes earlier! Ahaha
95kg x 3 reps on decline bench tonight f*k yea :D
body weight at 72kg
so apparently if you use the 'at' symbol and direct something to a member that doesn't exist it f**ks all kinds of shit up lol
Edited by UNR33L
epic thanks.
Just saved my self $8. Bought Lego with the saving. Good day :D
np, haha strong lego purchase! :D
body weight at 72kg
2strong m8.
haha yeah i think that happened to me earlier, wasn't sure why but i may have used an 'at' symbol... would make sense!
Go to NPC
Buy 10" organic for ~$500
Never look back
Yeah? They good are they?
Try Better Brakes in Cheltenham, haven't been there in a while but used to have very cheap exedy clutches.
Yeah Co-worker said he could probably get them cheaper through there.
Search NPC on these forums, or read the drivetrain sections. Always recommended. Mine is organic and rated to 300rwkw. Softer than the cushion button Exedy I was running before.
Cheapest place to get
Exedy Sports Organic Heavy Duty Clutch Kit ?
direct from excedy... got mine (HHHDBC) reeeeeeal cheap
would have to assume racepace would have an account with them or could start one at least
re insurance..
370 Comp daily drive insured value 27,500 all mods listed..
who with and how can i get said bargain?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
