Alvin and Tony!
You guys bought your coilpacks from Amayama yet????
Think I need some as my stag just started misfiring/hesitating after about 4k..... it just happens every now and then though, could be coilpacks right guys?
Check coil packs or sparkplugs
Lol Aaron. You do realise that curries are at the wrong end of the scale with regard to average penis size. We aren't black brah.
I was going to let it slide.... but since you mentioned it...
It is likely your thrust bearing rattling around in a resting state; there is nothing wrong with this. They tend to do this a lot in Skylines, as the thrust bearing will sit fairly flush against the pressure plate, which moves it around on the input shaft retainer. The moment you put your foot on the clutch pedal, it puts enough pressure on the bearing to press it firmly against the pressure plate, making the outside of the bearing engage whilst the inside is held firm in place by the clutch fork. You can spray lithium grease inside (stay away from the clutch area) to quieten the rattle a bit, or you can try to adjust your clutch so that the resting state of the clutch fork doesn't have the bearing sitting as close to the pressure plate.
Yes changing pivot ball is box out. Unless you have some very special tools, a keyhole surgery camera and a f**kload of patience.
How do I do this?
I might try the grease option, or adjusting the pedal. Is it bad to have the bearing tight against the pressure plate all the time?
How do I do this?
Try the grease first...that fixed my rattle sound. You basically want to grease the length of the input shaft retainer, because that's what the bearing is spinning around on and causing the rattle sound. You can adjust the pedal in the driver footwell, or by grinding some material off your slave cylinder pushrod / putting in a smaller rod.
As in simulatIng your foot resting on the pedal? It's not lethal, but also not fantastic for the bearing over time. There's no heavy weight on the ball bearings inside, but the bearing is not meant to be taking load 24/7...so it will likely reduce the life of the bearing...but it's a bit like saying it'll last you 100,000km instead of 150,000km.
I think my NPC bearing is fairly firmly pressed against the pressure plate and it has worn it a bit...I can feel it through the pedal. I have a hydraulic issue causing this though; the resting clutch fork pressure increases as the system heats up or climate becomes warmer.
Unless the rattle is very loud, it's nothing to worry about. As said, all Skylines do it. Grease will quieten it for a bit and you may have to do it again every oil change or so.
See? Pretty self explanatory
I find it funny that the whitest people on this forum are also the blackest, lol you birds and ric..
:rofl:
We all black...when the lights go out...
And pink on the inside...
Ah ok, thanks for that! I don't mind having to reapply, anything to shut the damn thing up.
If the grease doesn't fix it I'll just push the pedal down further, my motor will probably let go before the bearing does lol
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
