Nah Adam, ethanol does burn slower than petrol. It also burns cooler due to the hydrogen bonds in etOH, which requires a lot more energy to vapourise than petrol. Explains the lower EGTs when running etOH huh? Fact in point is bubble point of etOH which is only C2 is 70degrees, it is a trend that the more the carbons, the higher the bubble pt (high school chem i assume).
Petrol is basically C8, with various isomers and aromatics added in to increase octane rating, but they all have roundabout 6 to 8 carbons, and no oxygen in the molecule itself. Petrol itself boils at 90degrees, but the components are largely C8.
We can look at vapour pressure and heat of vapourisation to understand volatility. 896kJ of energy is required to vapourise 1kg of EtOH vs 298 for octane, which is the closes to petrol. This, is why it burns cooler and slower. Or at least why i understand it burns cooler and slower. I'll have to look up activation energies to further explain why etOH burns slower but i cbf now.
And that is why, it is probably better to go a hotter plug when you're using etOH as a fuel.
Had a headache by the end of the first paragraph you Kent's are too smart for me
Lol Alex, I was about to say the same.. Lol the only reason I know that ethanol burns slower is because I set it in fire at Scott's lol
I like fire
But yeh the bigger arc/gap makes sense!
Awesome thanks for the /skylinesaustralia discussion in the wasteland.
Thinking of buying bcpr7es-11 to see if misfire caused by heat range of plug. If issue still occurs, I'll drop them to 8mm?
Thoughts on this? Cheers
About to happen to me... very hungry so call my mate to go Subway/Schnitz.
Then Pho is brought up. Also very acceptable. Nek minnit his missus also coming (which is no problem... the problem is that she doesn't live *close* and now I have to wait longer until my food is in front of me :'( ).
tl;dr
getting pho, but have to wait :'(
Edited by kaitoukid
I'm still gonna say go to .8mm. I don't think you are chasing 350+kw I mean mine were .8 on all my cars. Never had an issue with making powerz
http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqpregap.asp?nav=31200&country=US
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
Interesting...
It does burn cooler, but from what I'm reading, not slower. Google has some conflicting results...some say faster, others say slower...and this also seems to change depending on AFRs too. Ethanol does have a higher autoignition point, making it less prone to detonation and harder to ignite than gasoline...but from what I understand, once ignited, will burn faster. I would like to know which one is correct, is there a way to test it without blowing ourselves up?
One thing is for certain...ethanol is awesome.
Ethanol burns slower but an increase in pressure changes it's burn rate drastically. There is also more oxygen to help it burn.
I have seen nearly 1000 degrees C in my manifold, so it certainly doesn't burn cold, just colder than dino 98. This is mainly due to extra timing though, as adding timing gives the fuel more time to burn in the cylinder, not in the exhaust.
^^ This. :)
well, burning both fuels at atmospheric would be very different to burning both fuels under cylinder conditions, cylinders have pressure between 160 to 200ish psi? that's from 10 to 15x atmospheric pressure.
mr aero engineer, any input?
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
