Nah Adam, ethanol does burn slower than petrol. It also burns cooler due to the hydrogen bonds in etOH, which requires a lot more energy to vapourise than petrol. Explains the lower EGTs when running etOH huh? Fact in point is bubble point of etOH which is only C2 is 70degrees, it is a trend that the more the carbons, the higher the bubble pt (high school chem i assume).
Petrol is basically C8, with various isomers and aromatics added in to increase octane rating, but they all have roundabout 6 to 8 carbons, and no oxygen in the molecule itself. Petrol itself boils at 90degrees, but the components are largely C8.
We can look at vapour pressure and heat of vapourisation to understand volatility. 896kJ of energy is required to vapourise 1kg of EtOH vs 298 for octane, which is the closes to petrol. This, is why it burns cooler and slower. Or at least why i understand it burns cooler and slower. I'll have to look up activation energies to further explain why etOH burns slower but i cbf now.
And that is why, it is probably better to go a hotter plug when you're using etOH as a fuel.
Had a headache by the end of the first paragraph you Kent's are too smart for me
Lol Alex, I was about to say the same.. Lol the only reason I know that ethanol burns slower is because I set it in fire at Scott's lol
I like fire
But yeh the bigger arc/gap makes sense!
Awesome thanks for the /skylinesaustralia discussion in the wasteland.
Thinking of buying bcpr7es-11 to see if misfire caused by heat range of plug. If issue still occurs, I'll drop them to 8mm?
Thoughts on this? Cheers
About to happen to me... very hungry so call my mate to go Subway/Schnitz.
Then Pho is brought up. Also very acceptable. Nek minnit his missus also coming (which is no problem... the problem is that she doesn't live *close* and now I have to wait longer until my food is in front of me :'( ).
tl;dr
getting pho, but have to wait :'(
Edited by kaitoukid
I'm still gonna say go to .8mm. I don't think you are chasing 350+kw I mean mine were .8 on all my cars. Never had an issue with making powerz
http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqpregap.asp?nav=31200&country=US
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
Interesting...
It does burn cooler, but from what I'm reading, not slower. Google has some conflicting results...some say faster, others say slower...and this also seems to change depending on AFRs too. Ethanol does have a higher autoignition point, making it less prone to detonation and harder to ignite than gasoline...but from what I understand, once ignited, will burn faster. I would like to know which one is correct, is there a way to test it without blowing ourselves up?
One thing is for certain...ethanol is awesome.
Ethanol burns slower but an increase in pressure changes it's burn rate drastically. There is also more oxygen to help it burn.
I have seen nearly 1000 degrees C in my manifold, so it certainly doesn't burn cold, just colder than dino 98. This is mainly due to extra timing though, as adding timing gives the fuel more time to burn in the cylinder, not in the exhaust.
^^ This. :)
well, burning both fuels at atmospheric would be very different to burning both fuels under cylinder conditions, cylinders have pressure between 160 to 200ish psi? that's from 10 to 15x atmospheric pressure.
mr aero engineer, any input?
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
