I wouldn't spend money on regularly detailing a car unless it was somethig special. But whatever car I drive in, I will always detail myself and wash weekly. I used to wash and wax the EA Falcon shitter I drove around in 3 years ago. Hardly worth it to most, but it was the cleanest looking EA Falcon around and the shine goes a long way in making any car look good (provided decent paint).
Thats what I like about my car... Looks smick when it's clean, even if it doesn't have the reflection quite as much as a black car would.... But even as it gets progressively dirtier it still looks good. You don't even notice how dirty it is until you clean part of it :P
Pat brings the paiiiiiiin
meh.. my jimmies ain't even rustled...
I had fake rims... fk yeah, i'm currently on my 3rd set!
(i've also had genuine rims a few times, and the only noticible difference was they cost more than twice as much)
Buys $150K+ car
Has money for HKS SSQV BOV
Top Secret Japan Engine Cover
Carbon Fiber shields to prevent air intakes sucking in hot air
Uses what looks to be a crunched up Diet Coke can for a catch can of to collect excess...
LOL! WUT?!
Is it just me or are Skylines actually becoming a rarity on the road? I see more 86s than 33s
yep..they are either getting smashed stolen or defected...everyone says im crazy when i tell em a GTST will be worth money oneday...or at least hold its value
s14s and 18os are holding their value well..even clapped out shitboxes go for 5k...
Buys $150K+ car
LOL! WUT?!
kinda like Dan's Midori buiit Nur spec
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
