lol dad had one too back in SL. Mum has a hand sized burn scar on her calf from the zorst when he dropped it on her when they were first seeing each other
haha, good recovery from that one :P
yeah my dad has scars on his knees to this day, from his mad cornering back in the day LOL. a few years back when on holiday there, he drove my uncles bike up the road for kicks. so maybe if i buy bike it will reignite dat passion :P
or he'll just kill me. whatevs. xD.
Legal loss recoveries.
I deal directly with our in house lawyer and help with claims as well as just remarket cars lol
The amount of work the lawyer herself does is fkn ridiculous.. Did a day course at Leo cussins or whatever it's called and wanted to kneck myself after.
Don't know how ric does it
Lawyer
Yeah but I bet not as nice as the one in Singapore I had. At least they were using thigh pieces of chicken on it so it actually resembled a proper chicken burger, well as best Maccas could :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
