boy did we read hsv's mind or what!
$100k and in the GTS only.
430 at the fly, so what? 350 odd rwkw... that's pretty fkn good for a stock car... but still less than a tuned FPV 5.0
But a tuned GTS... Hmmmmmmmmm
looks aids...
I'd rather the GT
either way, we dont know what the ancillary devices will withstand yet... they may be tunable to like 600kw... or they might blow up at 431
I don't mind the look of them.
its aids man....you can't take an old model, slap new style headlights and shit on it and expect it to look good...you now have a curvy front and rear end on a car that is still box shaped in the middle its ridiculous....Just like the VT it was ugly, they upgraded to vx and it looked a little better....because the lights were still round and suited its all round style...
then...
in anticipation of the new VE ,they created the VY-VZ by slapping square headlights and triangle taillights on what was still a curvy VT body..it looked f**king horrible...Luckily for Holden most people are blinded by the abnormally larger thing under the bonnet and don not realize how blatently lame their styling cues are...
then...
looks aids...
I'd rather the GT
Just had a baby
Buy an Evo
Buy a GT
You has money tree?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
