my boost gauge doesn't show any boost spike, goes to 10psi but settles down to 9psi.
During the misfiring revving pass 4k rpm, it makes a constant popping from my rear muffler from what I can tell.
I don't even know, I've been sitting here looking for excuses not to let it go...
evos are crappy little girls cars....is that reason enough...need another, your gfs car is cooler (almost) :P
Ed* oh wait you said excuses NOT to let it go...sorry I got nuthink..
1.1 is a bit big for turbo applications I thought. 0.8 is more common, stronger arc.
1.1 is standard for the rb25 but .8 is the norm for anything modded...
I just go to bursons and ask for rb20 plugs usually..they are the bpr6 blahdy blah whatever they are the ones you want :yes:
Still got it, need a normal one for roardworthy
Good for pho Sunday morning or lunch
Could even do Yum Cha
I bon bo hue
I'll let Alvin pick
my fav bun bo hue is in st albans, i dont think you guys want to drive that far right?
though yum cha @ gold leaf springy/burwood sounds good oto.
did you seriously just read all that crap we wrote to Pat about plug gaps THEN put in 1.1's already put them in? lol
take out plugs and gap to 0.8
missfire will mysteriously vanish
Lol as far as I'm aware, plugs wear by creating a larger gap. As the 1.1's wear they grow to 1.2+
This is when you start having misfires
It you start at 0,8 they will wear down to 0.9, 1.0
Drop to 0.8 if misfiring. Although I'm getting away with 1.1's at 220kw :)
I'm only running fmic and exhaust, boost sitting on 9psi after those mods.
Thought I'll be alright with 1.1mm since not running much power, shall re-gap to 0.8mm and perhaps coilpacks.
Misfiring better go away before deca!
Misfiring isn't only from increased pressure in the cylinder, it is caused by excessive amounts of fuel also. If they are running good AFR's in the top end and cylinder pressure is under control they should be able to run 1.1mm just fine, if not the coil packs may be flogged.
You are right, plugs do wear slowly. If they are wearing fast you may be overheating them, perhaps try a BPR7.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
