my boost gauge doesn't show any boost spike, goes to 10psi but settles down to 9psi.
During the misfiring revving pass 4k rpm, it makes a constant popping from my rear muffler from what I can tell.
I don't even know, I've been sitting here looking for excuses not to let it go...
evos are crappy little girls cars....is that reason enough...need another, your gfs car is cooler (almost) :P
Ed* oh wait you said excuses NOT to let it go...sorry I got nuthink..
1.1 is a bit big for turbo applications I thought. 0.8 is more common, stronger arc.
1.1 is standard for the rb25 but .8 is the norm for anything modded...
I just go to bursons and ask for rb20 plugs usually..they are the bpr6 blahdy blah whatever they are the ones you want :yes:
Still got it, need a normal one for roardworthy
Good for pho Sunday morning or lunch
Could even do Yum Cha
I bon bo hue
I'll let Alvin pick
my fav bun bo hue is in st albans, i dont think you guys want to drive that far right?
though yum cha @ gold leaf springy/burwood sounds good oto.
did you seriously just read all that crap we wrote to Pat about plug gaps THEN put in 1.1's already put them in? lol
take out plugs and gap to 0.8
missfire will mysteriously vanish
Lol as far as I'm aware, plugs wear by creating a larger gap. As the 1.1's wear they grow to 1.2+
This is when you start having misfires
It you start at 0,8 they will wear down to 0.9, 1.0
Drop to 0.8 if misfiring. Although I'm getting away with 1.1's at 220kw :)
I'm only running fmic and exhaust, boost sitting on 9psi after those mods.
Thought I'll be alright with 1.1mm since not running much power, shall re-gap to 0.8mm and perhaps coilpacks.
Misfiring better go away before deca!
Misfiring isn't only from increased pressure in the cylinder, it is caused by excessive amounts of fuel also. If they are running good AFR's in the top end and cylinder pressure is under control they should be able to run 1.1mm just fine, if not the coil packs may be flogged.
You are right, plugs do wear slowly. If they are wearing fast you may be overheating them, perhaps try a BPR7.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
