my boost gauge doesn't show any boost spike, goes to 10psi but settles down to 9psi.
During the misfiring revving pass 4k rpm, it makes a constant popping from my rear muffler from what I can tell.
I don't even know, I've been sitting here looking for excuses not to let it go...
evos are crappy little girls cars....is that reason enough...need another, your gfs car is cooler (almost) :P
Ed* oh wait you said excuses NOT to let it go...sorry I got nuthink..
1.1 is a bit big for turbo applications I thought. 0.8 is more common, stronger arc.
1.1 is standard for the rb25 but .8 is the norm for anything modded...
I just go to bursons and ask for rb20 plugs usually..they are the bpr6 blahdy blah whatever they are the ones you want :yes:
Still got it, need a normal one for roardworthy
Good for pho Sunday morning or lunch
Could even do Yum Cha
I bon bo hue
I'll let Alvin pick
my fav bun bo hue is in st albans, i dont think you guys want to drive that far right?
though yum cha @ gold leaf springy/burwood sounds good oto.
did you seriously just read all that crap we wrote to Pat about plug gaps THEN put in 1.1's already put them in? lol
take out plugs and gap to 0.8
missfire will mysteriously vanish
Lol as far as I'm aware, plugs wear by creating a larger gap. As the 1.1's wear they grow to 1.2+
This is when you start having misfires
It you start at 0,8 they will wear down to 0.9, 1.0
Drop to 0.8 if misfiring. Although I'm getting away with 1.1's at 220kw :)
I'm only running fmic and exhaust, boost sitting on 9psi after those mods.
Thought I'll be alright with 1.1mm since not running much power, shall re-gap to 0.8mm and perhaps coilpacks.
Misfiring better go away before deca!
Misfiring isn't only from increased pressure in the cylinder, it is caused by excessive amounts of fuel also. If they are running good AFR's in the top end and cylinder pressure is under control they should be able to run 1.1mm just fine, if not the coil packs may be flogged.
You are right, plugs do wear slowly. If they are wearing fast you may be overheating them, perhaps try a BPR7.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
